Hi, i installed ArcGIS Runtime Qt 10.2.3. Local server failed to start when i test the first sample. It seems the ArcGISRuntime::installDirectory() returns null because the path returned is not right. When i set the install path by using setInstallDirectory function, the local server works. However, the window popped up shows nothing.
Code:
QString mypath="/home/wu/arcgis/runtime_sdk/qt10.2.3";
EsriRuntimeQt::ArcGISRuntime::setInstallDirectory(mypath);
EsriRuntimeQt::ArcGISRuntime::setRenderEngine(EsriRuntimeQt::RenderEngine::OpenGL);
m_mapGraphicsView = EsriRuntimeQt::MapGraphicsView::create(m_map, this);
setCentralWidget(m_mapGraphicsView);
m_map.setWrapAroundEnabled(false);
// show Esri logo by default
m_map.setEsriLogoVisible(true);
QString path = EsriRuntimeQt::ArcGISRuntime::installDirectory();
path.append("/sdk/samples/data");
QDir dataDir(path); // using QDir to convert to correct file separator
QString pathSampleData = dataDir.path() + QDir::separator();
QString dataPath = pathSampleData + "mpks" + QDir::separator() + "USCitiesStates.mpk";
m_localMapService = EsriRuntimeQt::LocalMapService(dataPath);
// connect to signal that is emitted when the service is created successfully
connect(&m_localMapService, SIGNAL(serviceCreationSuccess(const QString&, const QString&)), this, SLOT(onLocalServiceCreationSuccess(const QString&, const QString&)));
// connect to signal that is emitted when the service failed
connect(&m_localMapService, SIGNAL(serviceCreationFailure(const QString&)), this, SLOT(onLocalServiceCreationFailure(const QString&)));
// start the service and the Local Server
m_localMapService.start();
