Hi!I try to use the arcpy.ListFields command. It only works when I type in the name of the shape file directly. It does not work when I try to use a shapefile name from a list.So to chekc my Code I added the print comand and it perfectly prints out the name of the shape.Example: 'River' But the code still doesn't work. If I enter 'River' manually it works perfectly fine.Any idea where the mistake might be?Thanks a lotDoesn't work:while x <= leta:
Listfieldx = str("'" + str(tableList)+"'")
print Listfieldx
fieldList = arcpy.ListFields(Listfieldx,"*","*")
I tried also fieldList = arcpy.ListFields(Listfieldx)fieldList = arcpy.ListFields(str(Listfieldx)) etc, etc...Does work:while x <= leta:
print Listfieldx
fieldList = arcpy.ListFields('River')
Best regards Chrisp.s. here the whole code#Export all the field properties of each table in the Geodatabse
import arcpy
from arcpy import env
# Overwrite pre-existing files
# Set the current workspace
# Set local variables
#Create a new table
try:
geoDataBasePath = "P:/RAME/GIS/2011/Report.mdb"
env.workspace = geoDataBasePath
NewTable = "FieldProperties"
arcpy.CreateTable_management(geoDataBasePath, NewTable)
# For each field in the feature class, print all properties
inFeatures = NewTable
fieldName1="name"
fieldName2="aliasName"
fieldName3="baseName"
fieldName4="domain"
fieldName5="isNullable"
fieldName6="precision"
fieldName7="required"
fieldName8="scale"
fieldName9="type"
fieldName10="length"
fieldName11="editable"
fieldName12="FC"
fieldLength=255
# Execute AddField new fields
arcpy.AddField_management(inFeatures, fieldName1, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName2, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName3, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName4, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName5, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName6, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName7, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName8, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName9, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName10, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName11, "TEXT", "", "", fieldLength)
arcpy.AddField_management(inFeatures, fieldName12, "TEXT", "", "", fieldLength)
#List all tables in the Geodatabase
tableList = arcpy.ListTables()
for table in tableList:
print table
#how many tables are there
leta = len(tableList)
print leta
x=0
#loop through all tables
while x <= leta:
print Listfieldx
print str(fieldList)
for field in fieldList:
print 1
NewList=[]
fc=str(tableList)
print fc
NewList.extend ([str(fc),str(field.name),str(field.aliasName),str(field.baseName),str(field.domain),str(field.isNullable),str(field.precision),str(field.required),str(field.scale), str(field.type),str(field.length),str(field.editable)])
print NewList
cursor = arcpy.InsertCursor(fc)
print 2
row = cursor.newRow()
row.FC=NewList[11]
row.name = NewList[0]
row.aliasName = NewList[1]
row.baseName = NewList[2]
row.domain = NewList[3]
row.isNullable = NewList[4]
row.precision = NewList[5]
row.required = NewList[6]
row.scale = NewList[7]
row.type = NewList[8]
row.length = NewList[9]
row.editable = NewList[10]
print 3
cursor.insertRow(row)
del NewList
x=x+1
del row
print 99
del cursor
del NewList
except:
print "\nError!\n"
del row
del cursor
del NewList
