I try to draw a real-time map based on one field. And I will update this field with another kept-on-generating dataframe. I forgo to finish it with updateCursor because it is so slow. Instead, I try to convert dbf into a csv file and merge it with that dataframe then convert it back to the dbf file.
It works well in 1st time. But since I have used the function TableToTable_conversion to generate a dbf file, it will add a table under that map in arcgis pro. Therefore I have to delete that table first before I run ableToTable_conversion to generate a generated dbf file. So what is the corresponding code in arcpy to delete that table?
BTW: I can visit these tables using this code:
tbs = mp.listTables()
for tb in tb:
print(tb.name)
