I'm attempting to concatenate several fields, where one of the source fields is a double, the rest are string, and all of them have some <Null> values. If I use the following syntax in Calculate Field in Pro 24.1/Python 3:
str(!AddrPrimaryHighNo!) + " " + str(!StreetPreDrctnAbbrev!) + " " + str(!StreetName!) + " " + str(!StreetSuffixAbbrev!) + " " + str(!StreetPostDrctnAbbrev!)
I get values like:
1498.0 None AVENUE K NONE NONE
where I would expect:
1498 AVENUE K
AddrPrimaryHighNo is Double
StreetPreDrctnAbbrev is Text
StreetName is Text
StreetSuffixAbbrev is Text
StreetostDrctnAbbrev is Text
If I perform the field calculation below in ArcMap 10.5.1/VB Script, it works out just fine:
[AddrPrimaryHighNo]&" "& [StreetPreDrctnAbbrev]&" "& [StreetName]&" "& [StreetSuffixAbbrev]&" "& [StreetPostDrctnAbbrev]
Meanwhile I'm just going to go back to ArcMap. Thanks
-Justin
