Had a couple of quick questions about customizing the ribbon in ArcGIS Pro.
Using the Customize the Ribbon interface I've found in that if I remove an item (the Analysis tab for instance) from the ribbon in I cannot add it again. I have the option to reset all customizations but the option to Add-> an item is always grayed out. Am I missing something here?
Would also like to set the customization by the project, not the machine. Can this be done at the project level?
Using ArcGIS Pro 1.1.1
