I took a look at the drawing tools example and got it up and running fairly quickly (I seperated out the html code and the js code into two seperate files). I see the toolbar.deactivate(); method works in the example but I can't get it to work in my code. I'm adding it everywhere and I even created a button to deactivate it. dojo.connect(dojo.byId("drawPolygon"),"click", function(){ tb.deactivate(); http://developers.arcgis.com/en/javascript/jsapi/draw.htmlIt just doesn't work!Here's my code[HTML] <!-- ******************** Spatial Select Button ***************************--> <div id="info"> <div>Select a shape then draw on map to add graphic</div> <button id="deactivateDraw" data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ initToolbar();}'>DeActivate</button> <button id="drawExtent" data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ initToolbar();}'>Extent</button> <!--button id="drawPolygon" data-dojo-type="dijit.form.Button">Polygon</button--> </div> <!-- ******************** End Spatail Select Button ***************************-->[/HTML] var tb; //toolbar for draw tools //*************** TOOLBAR CODE ****************************** function initToolbar() { tb = new esri.toolbars.Draw(map); dojo.connect(tb, "onDrawEnd", addGraphic); dojo.connect(dojo.byId("drawExtent"),"click", function(){ tb.activate(esri.toolbars.Draw.EXTENT); map.hideZoomSlider(); }); dojo.connect(dojo.byId("deactivateDraw"),"click", function(){ tb.deactivate(); map.showZoomSlider(); }); } //*************** END TOOLBAR CODE ****************************** function addGraphic(geometry) { // try to deactivate the toolbar and clear existing graphics var symbol; tb.deactivate(); //doesn't work map.showZoomSlider(); //works map.graphics.clear(); //works switch (geometry.type) { case "point": case "multipoint": symbol = new esri.symbol.SimpleMarkerSymbol(); break; case "polyline": symbol = new esri.symbol.SimpleLineSymbol(); break; default: symbol = new esri.symbol.SimpleFillSymbol(); break; } var graphic = new esri.Graphic(geometry, symbol); map.graphics.add(graphic); tb.deactivate(); } //*************** END TOOLBAR CODE ******************************
