Is it possible to block all add-ins in a configuration and still load the configuration's module(s)? If I set
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>AddIns</SPAN> <SPAN class="attr-name token">securityLevel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>4<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
then the configuration's module won't load.
