Hello everyone!
I try to create a scene app with JS API 4.x. I have installed and configured Portal, ArcGIS Server, DataStore properly (Server is a hosted server for Portal), everything is working fine except one thing.
My problem is: when I publish a scene from ArcGIS Pro 1.1, it only creates a FeatureServer and MapServer instance in the REST. But as far as I know, there should be a SceneServer also which I could add into my 3d app created with JS API 4.x. But that one is just not there.
I found a working example online which uses a sceneLayer with the following url: http://scene.arcgis.com/arcgis/rest/services/Hosted/Building_Hamburg/SceneServer/layers/0
As you can see, this is a proper SceneServer service, and the objects (buildings) are visible on the 3d map in the browser.
How could I create the SceneServer service? What was I missing?
Best,
Gergely
