I keep getting this ValidateAddinXMLTask error:
Severity | Code | Description | Project | File | Line | Suppression State |
Error | | The "ValidateAddInXMLTask" task failed unexpectedly.System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.VisualStudio.Shell.12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. Het systeem kan het opgegeven bestand niet vinden.File name: 'Microsoft.VisualStudio.Shell.12.0, Version=12.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' at ESRI.ArcGIS.AddIns.SDK.MSBuild.ValidateAddInXMLTask.Execute() at Microsoft.Build.BackEnd.TaskExecutionHost.Microsoft.Build.BackEnd.ITaskExecutionHost.Execute() at Microsoft.Build.BackEnd.TaskBuilder.<ExecuteInstantiatedTask>d__26.MoveNext()WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. | lijstEigenaars105 | | | |
Installing visual studio 2013 sdk should solve it. But I can't find the dll anywhere.
Is there a workaround? Anyone else having this problem?
