My web master is trying to run a query against a feature service stored in AGOL. The link is
https://services.arcgis.com/DknzyjEEie5tEW0u/ArcGIS/rest/services/CRT_Bridges_Public/FeatureServer/0/query
Despite the pagination beings set to true the result offset is not stepping beyond the points brought in initially.
The form is being filled out as follows:
WHERE = OBJECTID > 0
OUT FIELDS = *
OUTPUT SPATIAL REFERENCE = 4326
ORDER BY FIELDS = OBJECTID
FORMAT = JSON
executing a Query(GET)
Which returns the values 1-2000 with no problem. If I change the where clause to be
WHERE = OBJECTID > 2000
The results 2001-4000 are returned.
However, if I use t he original criteria and add
RESULT OFFSET = 2000
The results returned continue to be 1-2000.
I'm hoping I am simply missing something straight forward. Any ideas?
