Greetings AllI've been stuck on this for most of this evening and would really like to know why its not working.I'm doing a MosaicToNewRaster with a bunch of rasters that need to be mosaiced with a particular raster.All I need is a simple ListRasters to get each raster from the bunch, keep the particular raster in a separate variable, feed the two to the Mosaic tool and it should be sweet.But no.At first, the loop script ran without errors, but the results were empty.So I decided to go back to basics and try to get that to work with two fixed variablesHere's the code:bathtub = "C:/Temp/dustin.gdb/Coastal_WD_2040"
inRas = "C:/Temp/dustin.gdb/depth_2040"
arcpy.MosaicToNewRaster_management("bathub;inRas","C:/Temp/dustin.gdb", "new_test", "#","32_BIT_FLOAT","#", "1", "MAXIMUM", "REJECT")
But it keeps returning a generic "ERROR 000582: Error occurred during execution"If I put in the full paths then of course it works...but I need it to loop.I thought I'd be smart about and get ModelBuilder to show me where I was going wrong.I built the same two variables and feed it to the tool and it ran with full success.So I exported the model to python script and guess what? it creates the necessary variables but then does not use them in the tool. Instead it uses the full path #ESRIFAILIn past readings on this forum, I came across arcpy.Raster() which creates a Raster object from the raster.I tried that too...and that didn't work.I subsituted the # for just "" for the optional values and that didn't work either.I tried every combination of r"", \ and even // for the file paths but still nothing.Any suggestions?
