Hi RobertYou had been assisting me with an Issue regarding the identify widget in a separate thread located here.I wanted to start a new thread so that you could get credit for answering a question should you be able to do that for me (I have no doubts that you will be able to help)The previous thread is located In this link I have now narrowed this down to an Issue with the particular featureI added our Manholes to the XML and these were identifiable using the following XML<?xml version="1.0" ?> <configuration> <betareturngeometryfix>false</betareturngeometryfix> <identifylayeroption>visible</identifylayeroption> <identifytolerance>5</identifytolerance> <defaultzoomscale>2000</defaultzoomscale> <keepidentifyactive>true</keepidentifyactive> <returngeometryforzoom>false</returngeometryforzoom> <enablelineselect>true</enablelineselect> <enbleextentselect>true</enbleextentselect> <enablepolyselect>true</enablepolyselect> <enablemouseovergraphicsinfo>false</enablemouseovergraphicsinfo> <enablemouseoverrecordinfo>false</enablemouseoverrecordinfo> <usemaptime>false</usemaptime> <autoactivatedtool>point</autoactivatedtool><!-- possible values are extent or polygon or mappoint or polyline or nothing --> <labels> <zoom2message>Click to Zoom to Point</zoom2message> <identifylabel>Identify</identifylabel> <resultslabel>Results</resultslabel> <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel> <pointlabel>Identify by Point</pointlabel> <linelabel>Identify by Polyline</linelabel> <rectlabel>Identify by Rectangle</rectlabel> <polylabel>Identify by Polygon</polylabel> <clearlabel>Clear</clearlabel> <loadinglabel>Loading...</loadinglabel> </labels> <useproxy> <proxylayer> <!--name>Imagery</name--> </proxylayer> </useproxy> <layers onlythese="true"> <layer> <name>Manholes</name> <fields>UGS_ID,NEIGHBORHO</fields> <links> <link includeinresults="false" field="" alias=""> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix></iconsuffix> </link> </links> <zoomscale>2000</zoomscale> <forcescale>false</forcescale> </layer> <layer> <name>Pole Master</name> <fields>POLEID,MUNI</fields> <links> <link includeinresults="false" field="" alias=""> <linkprefix></linkprefix> <linksuffix></linksuffix> <iconfield></iconfield> <iconprefix></iconprefix> <iconsuffix></iconsuffix> </link> </links> <zoomscale>2000</zoomscale> <forcescale>false</forcescale> </layer> </layers> <symbols> <simplefillsymbol color="0x448ccb" alpha="0.4" style="solid"> <outline color="0x448ccb" alpha="0.8" width="2"/> </simplefillsymbol> <simplemarkersymbol style="circle" size="12" color="0x448ccb" alpha="0.8" xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0xffffff" alpha="0.8" width="1"/> </simplemarkersymbol> <picturemarkersymbol url="assets/images/i_info.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0x448ccb" alpha="0.8" width="2"/> </symbols> </configuration>
However the Pole Master features are not returned in the identify resultsHere is my REST end point Layer: Pole Master (ID: 0)Display Field: POLEIDType: Feature LayerGeometry Type: esriGeometryPoint......Fields: OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID) POLEID (Type: esriFieldTypeString, Alias: POLEID, Length: 16 ) MUNI (Type: esriFieldTypeString, Alias: MUNI, Length: 20 ) .......The Pole Master Table is a bit of beast and we are in the process of restructuring it however this wont be for the next 6-12 months. Any ideas why the Manholes show but the Poles do not?I will post the IE Dev mode response in the next post as it took me over the limitThanks for any assistance you are able to provideAl
