Hey guys,
I am stuck on an older version of Arc For Server (10.0) and currently have a webmap created with Flex. Obviously this is old and deprecated and I'd like to use a javascript based solution. I know a little bit of leaflet/javascript.
My understanding is there are two options: ArcGIS Online or a Portal. The data is from our ArcSDE which is huge so I think ArcGIS Online would be out of the question and would need a local portal based solution. I like the idea of the WebApp Builder but I can't see anywhere what the minimum requirements are. I assume you need portal in my situation which is 10.3?
Can I use the Javascript API to manually create what web app builder would do? or is there a minimum Arc For server version requirement for the JS API as well?
