I am developing a Python Toolbox to take some user inputs before creating an output that gets saved as an Excel file. I'm trying to have it add the '.xls' extension after the user enters a file name but then it shows errors in the dialog box:
The errors go away once the file name is entered and it does automatically add the file extension. How do I write the code so that there are no errors to begin with?
This is my first attempt at a Python Toolbox but I think I will be developing more so I'm willing to take any help that I can get. Here is my source code:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
planList<SPAN class="operator token">=</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'Greentree'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Sunset'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'Sherwood'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">return</SPAN> planList
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Toolbox</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">__init__</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Toolbox"</SPAN>
self<SPAN class="punctuation token">.</SPAN>alias <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>
<SPAN class="comment token"># List of tool classes associated with this toolbox</SPAN>
self<SPAN class="punctuation token">.</SPAN>tools <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>Tool<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Tool</SPAN><SPAN class="punctuation token">(</SPAN>object<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Define the tool (tool name is the name of the class)."""</SPAN>
self<SPAN class="punctuation token">.</SPAN>label <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Tool"</SPAN>
self<SPAN class="punctuation token">.</SPAN>description <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN>
self<SPAN class="punctuation token">.</SPAN>canRunInBackground <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">False</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">getParameterInfo</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Define parameter definitions"""</SPAN>
planBuff<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">'planBuff'</SPAN><SPAN class="punctuation token">,</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">'Buffer Distance'</SPAN><SPAN class="punctuation token">,</SPAN>
direction<SPAN class="operator token">=</SPAN><SPAN class="string token">'Input'</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">'GPDouble'</SPAN><SPAN class="punctuation token">,</SPAN>
parameterType<SPAN class="operator token">=</SPAN><SPAN class="string token">'Required'</SPAN><SPAN class="punctuation token">)</SPAN>
planBuff<SPAN class="punctuation token">.</SPAN>value<SPAN class="operator token">=</SPAN><SPAN class="number token">50</SPAN>
units<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">'units'</SPAN><SPAN class="punctuation token">,</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">'Units'</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">'GPString'</SPAN><SPAN class="punctuation token">,</SPAN>
units<SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">=</SPAN> <SPAN class="string token">"ValueList"</SPAN>
units<SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>list <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'feet'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'meters'</SPAN><SPAN class="punctuation token">]</SPAN>
units<SPAN class="punctuation token">.</SPAN>value<SPAN class="operator token">=</SPAN><SPAN class="string token">'feet'</SPAN>
plan<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">'plan'</SPAN><SPAN class="punctuation token">,</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">'Plan Name'</SPAN><SPAN class="punctuation token">,</SPAN>
plan<SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>type<SPAN class="operator token">=</SPAN><SPAN class="string token">'ValueList'</SPAN>
plan<SPAN class="punctuation token">.</SPAN>filter<SPAN class="punctuation token">.</SPAN>list<SPAN class="operator token">=</SPAN>getList<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
folder<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">'folder'</SPAN><SPAN class="punctuation token">,</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">'Folder to save file'</SPAN><SPAN class="punctuation token">,</SPAN>
datatype<SPAN class="operator token">=</SPAN><SPAN class="string token">'DEFolder'</SPAN><SPAN class="punctuation token">,</SPAN>
fileName<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>Parameter<SPAN class="punctuation token">(</SPAN>
name<SPAN class="operator token">=</SPAN><SPAN class="string token">'fileName'</SPAN><SPAN class="punctuation token">,</SPAN>
displayName<SPAN class="operator token">=</SPAN><SPAN class="string token">'Excel file name'</SPAN><SPAN class="punctuation token">,</SPAN>
params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>planBuff<SPAN class="punctuation token">,</SPAN>units<SPAN class="punctuation token">,</SPAN>plan<SPAN class="punctuation token">,</SPAN>folder<SPAN class="punctuation token">,</SPAN>fileName<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">return</SPAN> params
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">isLicensed</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Set whether tool is licensed to execute."""</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateParameters</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="operator token">not</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText<SPAN class="punctuation token">.</SPAN>endswith<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'xls'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="operator token">=</SPAN>parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText<SPAN class="operator token">+</SPAN><SPAN class="string token">'.xls'</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">updateMessages</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">,</SPAN> messages<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""The source code of the tool."""</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
