Hello everyone !I work on ArcGIS 9.3 and I'd want to execute many queries in a row with Python.Actually I have a layer, called "lines" that contains all the bus lines of a city. And my question is : how to save each line in a different layer ? I thought the best thing to do would be : - a query by attributes : field used : "blines". Characterizes the number of the lines (1, 2, 3 and so on)- and then to save each query in a distinct layerA good solution would be a loop in order to make the computation faster but I don't really know how to do. I tried to make that script but I guess I'm very far from the right result :
import sys, string, os, arcgisscripting
gp = arcgisscripting.create(9.3)
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Variables in local
lines_shp = "d:\\Travaux\\NantesMetropole\\lines.shp"
test = ["blines"]
while 1:
for i in test:
try:
gp.Select_analysis(lines_shp, i_shp, i)
print "Query successful"
except:
print "Error"
break
Have you got any ideas ?Thank you !Julien
