I'm trying to bulk upload multiple attachments to an AGOL feature service. I add the feature service as a layer in ArcGIS desktop and try to "Add Attachments". There error is that the database is locked for editing. So I create a local copy of the service and run the "Add Attachments" tool. I verify that the attachments are added, but after I sync it, the attachments are not synced to the feature service.
If I try to start editing the local database, the tool does not work because it does not work on an editable database. If I run the "Add Attachments" tool first and then run a calculate field for all the records (to try to trick it), it still does not upload attachments.
Has anyone found a method around this issue?
