I wrote code for an editor widget based on this page: Default editing widget | ArcGIS API for JavaScript
It looks like I have all the required information in my code, but I don't see my symbols displaying in the editorDiv and I can not edit the symbols on the feature layer on the map. The feature layer is set up for editing. I don't receive any errors in Google Chrome.
Any ideas what is wrong with this code:
<!DOCTYPE html>
<html>
<head>
<title>Decatur Graphics Editor</title>
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body, #mapDiv
padding:0;
margin:0;
height:100%;
width:100%;
position:absolute;
z-index:0;
/* Editor style begin */
#templatePickerPane {
width: 200px;
height:300px;
overflow: hidden;
z-index:50;
top:50%;
right:0%;
position:absolute;
#panelHeader
background-color: #92A661;
border-bottom: solid 1px #92A860;
color: #FFF;
font-size: 18px;
height: 24px;
line-height: 22px;
margin: 0;
overflow: hidden;
padding: 10px 10px 10px 10px;
#editorDiv
background-color:White;
.esriEditor .templatePicker
padding-bottom: 5px;
padding-top: 5px;
height: 500px;
border-radius: 0px 0px 4px 4px;
border: solid 1px #92A661;
.dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content
position: relative;
/* Editor Style End */
</style>
<script src="http://js.arcgis.com/3.11/" type="text/javascript"></script>
<script type="text/javascript">
var map;
require(["esri/map", "esri/config",
"esri/geometry/Extent",
"esri/dijit/editing/Editor",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/SnappingManager",
"esri/tasks/GeometryService",
"esri/toolbars/draw",
"dojo/dom",
"dojo/keys",
"dojo/on",
"dojo/parser",
"dojo/_base/array",
"dojo/i18n!esri/nls/jsapi",
"dojo/dnd/Moveable",
"dojo/domReady!"], function (Map, esriConfig, Extent, Editor, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
FeatureLayer, SnappingManager, GeometryService, Draw, dom, keys, on, parser, arrayUtils, i18n, Moveable
parser.parse();
//snapping is enabled for this sample - change the tooltip to reflect this
i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
/* The proxy comes before all references to web services */
/* Files required for security are proxy.config, web.config and proxy.ashx
- set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
(Roles are not required)
The proxy section is defined on the ESRI sample. I have included it as
part of the documentation reads that the measuring will not work.
I thought that might be important.
// Proxy Definition Begin
//identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
//If this null or not available the project and lengths operation will not work.
// Otherwise it will do a http post to the proxy.
esriConfig.defaults.io.proxyUrl = "proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = true;
// Proxy Definition End
// declare geometry service
esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
// set custom extent
var initialExtent = new Extent({
"xmin": 777229.03,
"ymin": 1133467.92,
"xmax": 848340.14,
"ymax": 1185634.58,
"spatialReference": {
"wkid": 3435
// create map and set slider style to small
map = new Map("mapDiv", {
showAttribution: false,
sliderStyle: "small",
extent: initialExtent
map.on("layers-add-result", initEditing);
// add imagery
var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
map.addLayer(tiled);
// set operational layers
var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
// add operational layers
map.addLayer(operationalLayer);
// add point feature layer
var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0", {
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"]
map.addLayer(pointFeatureLayer);
map.infoWindow.resize(400, 300);
function initEditing(event) {
var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
return {
"featureLayer": layer.layer
var settings = {
map: map,
layerInfos: featureLayerInfos
var params = {
settings: settings
var editorWidget = new Editor(params, 'editorDiv');
editorWidget.startup();
var options = { snapKey: keys.copyKey };
map.enableSnapping(options);
</script>
</head>
<body class="soria">
<div id="mapDiv">
</div>
<div id="templatePickerPane">
<div id="panelHeader">
Default Editor
</div>
<div style="padding:10px;" id="editorDiv">
</div>
</div>
</body>
</html>
