I'm writing a python toolbox implementing several different areal interpolation methods, from the most basic areal weighting up to methods that use some statistical techniques.
I'm planning on running some monte carlo simulations to assess the accuracy of each method with a particular set of input data, so I need to make the execution as quick as possible.
My current implementation for areal weighting is below. I've used a searchcursor nested within an updatecursor, which I'm led to believe is not the most efficient way.
Basically the task is to interpolate values from source zones (census polygons) to arbitrary target zone polygons, in this case based simply on the ratio of the area of each source zone that intersects a target zone to the total area of that source zone.
To do this, I loop through the target zones, select just the source zones that intersect the target zone, then loop through those source zones. Where the source zone is entirely contained within the target zone, I just take the total value from that source zone (I'm not sure if this optimization is worth it as all I save is the ratio calculation...), otherwise, I calculate the ratio and multiply it by the value to be interpolated.
I've been trying to think of a way to avoid this inner searchcursor by creating a dictionary outside the updatecursor. The difficulty is that this dictionary does not need to include all the source zones, just those that intersect the target zone. Ideally I'd have a dictionary with the ID of each target zone as the key, and the value would have to be another dictionary for each intersecting source zone with the interpolation and geometry fields as keys and the values of those fields as values. But it seems like to build this dictionary would require running an intersect or spatial join first, or another nested loop, so I'm unsure whether I would really gain much speed this way.
I know I can use cProfile to see exactly how long each part is taking, but it's not clear how best to set it up within a python toolbox - can anyone provide some examples of how best to do this?
Anyway, here is the execute code:
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> parameters<SPAN class="punctuation token">,</SPAN> messages<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""The source code of the tool."""</SPAN>
<SPAN class="comment token"># get parameters</SPAN>
inSourceFeatures <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
inInterpolationFields <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN>
inTargetFeatures <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
outTargetFeatures <SPAN class="operator token">=</SPAN> parameters<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>valueAsText
<SPAN class="comment token"># use in_memory workspace for quicker results</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> <SPAN class="string token">'in_memory'</SPAN>
<SPAN class="comment token"># make feature layers of the source zone feature class</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>inSourceFeatures<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"source_zones"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># take a copy of the target zones</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN>inTargetFeatures<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"target_zones"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># add fields for the interpolated variables</SPAN>
<SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> inInterpolationFields<SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"target_zones"</SPAN><SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># get spatial reference of zones</SPAN>
sourceSR <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"source_zones"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>spatialReference
targetSR <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"target_zones"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>spatialReference
<SPAN class="comment token"># for each target zone...</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"target_zones"</SPAN><SPAN class="punctuation token">,</SPAN> inInterpolationFields <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> spatial_reference<SPAN class="operator token">=</SPAN>targetSR<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> targetCursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> targetRow <SPAN class="keyword token">in</SPAN> targetCursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># create a dictionary for the row for easier field access</SPAN>
targetRowDict <SPAN class="operator token">=</SPAN> dict<SPAN class="punctuation token">(</SPAN>zip<SPAN class="punctuation token">(</SPAN>inInterpolationFields <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> targetRow<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># get target geometry</SPAN>
targetGeom <SPAN class="operator token">=</SPAN> targetRowDict<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># select source zones that intersect current target zone</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByLocation_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"source_zones"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"INTERSECT"</SPAN><SPAN class="punctuation token">,</SPAN> targetGeom<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># initialise output interpolated value fields</SPAN>
targetRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> <SPAN class="number token">0.0</SPAN>
<SPAN class="comment token"># for each intersecting source zone...</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"source_zones"</SPAN><SPAN class="punctuation token">,</SPAN> inInterpolationFields <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> spatial_reference<SPAN class="operator token">=</SPAN>sourceSR<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> sourceCursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> sourceRow <SPAN class="keyword token">in</SPAN> sourceCursor<SPAN class="punctuation token">:</SPAN>
sourceRowDict <SPAN class="operator token">=</SPAN> dict<SPAN class="punctuation token">(</SPAN>zip<SPAN class="punctuation token">(</SPAN>inInterpolationFields <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> sourceRow<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># get source geometry</SPAN>
sourceGeom <SPAN class="operator token">=</SPAN> sourceRowDict<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># if source zone is entirely within the target zone, add the full value</SPAN>
<SPAN class="keyword token">if</SPAN> sourceGeom<SPAN class="punctuation token">.</SPAN>within<SPAN class="punctuation token">(</SPAN>targetGeom<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> sourceRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
targetRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+=</SPAN> sourceRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token"># calculate the ratio of the intersection area to the source zone area</SPAN>
ratio <SPAN class="operator token">=</SPAN> sourceGeom<SPAN class="punctuation token">.</SPAN>intersect<SPAN class="punctuation token">(</SPAN>targetGeom<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>area <SPAN class="operator token">/</SPAN> sourceGeom<SPAN class="punctuation token">.</SPAN>area
<SPAN class="comment token"># add the areally weighted values to the output fields</SPAN>
targetRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+=</SPAN> ratio <SPAN class="operator token">*</SPAN> sourceRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN>
targetCursor<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>targetRowDict<SPAN class="punctuation token">[</SPAN>field<SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> field <SPAN class="keyword token">in</SPAN> inInterpolationFields <SPAN class="operator token">+</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># copy output target zones to output</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CopyFeatures_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"target_zones"</SPAN><SPAN class="punctuation token">,</SPAN> outTargetFeatures<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
