I'm trying to figure out if you can configure a feature class stored in an SQL geodatabase to dynamically update latitude and longitude values based on current locations rather than the last time the values were manually calculated. I found one resource that referenced a Dynamic Update XY and Toggle Automatic Update XY tools, but they seem to be specific to the Aviation solutions in ArcGIS, which we do not use.
Defining settings to update X,Y coordinates and geometry dynamically—Help | ArcGIS Desktop
Is there a way to configure something very similar to this in the normal ArcMap environment when referencing a point feature class stored in an SQL geodatabase?
