[ATTACH=CONFIG]33521[/ATTACH]I currently have a Table of Contents working from a Dynamic Map Service under the Layers button. I would like to add a few RSS layers under the RSS Layers Button with a check box and name. I can't figure out why the checkbox is not appearing for my rss layer. I assume has to do with map.on("layers-add-result",......<!DOCTYPE html>
<html>
<head>
<title>Map</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
<link rel="stylesheet" type="text/css" href="http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs/css/agsjs.css" />
<style>
html, body {
height: 100%;
width: 100;
margin: 0;
padding: 0;
font-family: helvetica, arial, sans-serif;
font-size: 90%;
color: #00151;
#map {
padding: 0;
overflow: hidden;
background-color:#0072AF; color:#0072AF;
#header {
margin:0px;
padding: 0px;
text-align:right;
background: -webkit-gradient(linear, left top, left bottom, from(#005b8c), to(#1980b7));
border: solid 1px #000000;
height: 56px;
#bookmarks-wrapper {
position: absolute;
z-index: 40;
top: 15px;
right: 30px;
background: transparent;
font-size: 12pt;
color: #444;
#Search-wrapper {
position: absolute;
z-index: 40;
top: 15px;
right: 140px;
font-size: 12pt;
color: #444;
#RssLayers-wrapper {
position: absolute;
z-index: 40;
top: 15px;
right: 265px;
font-size: 12pt;
color: #444;
#title {
font-size:150%;
color: #ffffff;
text-align:center;
margin: 2px;
#subfooter {
font-size:small;
color: #ffffff;
font-size:13px;
text-align:center;
margin: 2px;
.esriControlsBR {
display: none;
/* this line hides layers when out of scale for the inline TOC
.agsjsTOCOutOfScale {
display: none
</style>
<script type="text/javascript">
var djConfig = {parseOnLoad: true, packages: [{"name": "agsjs","location": "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs" }] };
</script>
<script src="http://js.arcgis.com/3.8/"></script>
var map, toc, dynaLayer1;
require(["dojo/_base/connect",
"dojo/parser",
"esri/urlUtils",
"dojo/on",
"agsjs/dijit/TOC",
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/dijit/Geocoder",
"esri/layers/GeoRSSLayer",
"esri/InfoTemplate",
"dojo/_base/array",
"esri/symbols/PictureMarkerSymbol",
"esri/renderers/SimpleRenderer",
"dijit/form/CheckBox",
"dojo/dom",
"dojo/dom-construct",
"dijit/form/DropDownButton",
"dijit/form/Button",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/fx",
"dojo/domReady!"],
function (connect, parser,urlUtils, on, TOC, Map, ArcGISDynamicMapServiceLayer, Geocoder,GeoRSSLayer,InfoTemplate,array, PictureMarkerSymbol, SimpleRenderer, CheckBox, dom, domConstruct) {
//call the parser to create the layout dijits
parser.parse();
map = new Map("map", {
center: [-93.00, 35.768],
zoom: 4,
basemap: "streets"
///Proxy
// Dyanmic layer For Table of Contents
dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://maps5.gisworkshop.com/ArcGIS/rest/services/McKenzieTaxDirector/MapServer");
map.on('layer-add-result', function (e) {
dynaLayer1.setVisibleLayers([0]);
toc = new TOC({
map: map,
layerInfos: [{
layer: dynaLayer1,
title: "McKenzie Parcels",
collapsed: true,
slider: false
}, 'tocDiv');
toc.startup();
map.addLayer(dynaLayer1);
///Geocoding Service
var geocoder = new Geocoder({
placeholder: "",
url: "",
map: map,
autoComplete: true,
},"search");
geocoder.startup();
// var georssUrl = "http://geocommons.com/overlays/116926.atom"; // S.F. and East Bay Breweries http://geocommons.com/overlays/116926
var rssBeer = new GeoRSSLayer("http://geocommons.com/overlays/116926.atom", {id: "Beer"});
rssBeer.on("load", function () {
//domStyle.set("loading", "display", "none");
// create an info template
var template = new InfoTemplate("${title}", "<tr><td></td><td>${description}</td></tr><br/><br/><tr><td> <a href=${link} target=_blank> BeerLine </a></td></tr></br>");
// set the info template for the feature layers that make up the GeoRSS layer
// the GeoRSS layer contains one feature layer for each geometry type
var layers = rssBeer.getFeatureLayers();
var picRenderer = new PictureMarkerSymbol("http://static.arcgis.com/images/Symbols/Basic/RedShinyPin.png", 21, 21);
var georssRenderer = new SimpleRenderer(picRenderer);
array.forEach(layers, function (l) {
l.setInfoTemplate(template);
l.setRenderer(georssRenderer)
//add the legend
map.on("layers-add-result", function (evt) {
var layerInfo = array.map(evt.layers, function (layer,
index) {
return {
layer: layer.layer,
title: layer.layer.name
//add check boxes
array.forEach(layerInfo,
function (layer) {
var layerName = layer.title;
if (layer.layer.id === "Beer") { layerName = "My Beer";}
var checkBox = new CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function (evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the check box and label to the TOC
domConstruct.place(checkBox.domNode, "toggle",
"after");
var checkLabel = domConstruct.create('label', {
'for': checkBox.name,
innerHTML: layerName
}, checkBox.domNode, "after");
domConstruct.place("<br />", checkLabel,
"after");
map.addLayers([rssBeer]);
}); // End Main Function ///////
</script>
</head>
<body class="tundra">
<div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
<div id="header" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
<div id="title">Title Main
<div id="subfooter">SubTitle</div>
</div>
<!-- Bookmarks widget inside a Drop Down Button -->
<div id="bookmarks-wrapper">
<div data-dojo-type="dijit/form/DropDownButton" region="top"> <span>Layers</span>
<div data-dojo-type="dijit/TooltipDialog">
<div id="tocDiv"></div>
</div>
</div>
</div>
<!-- Search widget inside a Drop Down Button -->
<div id="Search-wrapper">
<div data-dojo-type="dijit/form/DropDownButton" region="top"> <span>Address</span>
<div id="search"></div>
</div>
</div>
</div>
<div id="RssLayers-wrapper">
<div data-dojo-type="dijit/form/DropDownButton" region="top"> <span>Rss Layers</span>
<h3>Layers</h3>
<br>
<div id="toggle" style="padding: 2px 2px;"></div>
</div>
</div>
</div>
</div><!-- End Header -->
<div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">
</div> <!-- End Map-->
</div>
</div>
</body>
</html>
