All,The script is almost complete. I am attempting to have the user input the six values as strings, then the script selects and zooms to feature. I am running into a syntax error within the whereClause. Any suggestions as to why?#Import import arcpy #Variables TOWNSHIP = arcpy.GetParameterAsText(0) RANGE = arcpy.GetParameterAsText(1) SEC = arcpy.GetParameterAsText(2) SUBCODE = arcpy.GetParameterAsText(3) BLOCK = arcpy.GetParameterAsText(4) LOT = arcpy.GetParameterAsText(5) mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] lyr = arcpy.mapping.ListLayers(mxd, "Parcels", df)[0] #Logic try: whereClause = ""TOWNSHIP" AND "RANGE" AND "SEC" AND "SUBCODE" AND "BLOCK" AND "LOT" = '"+Parcels+"'" arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", whereClause) df.extent = lyr.getSelectedExtent() df.scale = df.scale*1.1 except: print arcpy.GetMessages()
