Hello
I am working on an automated way of publishing map services to a Federated ArcGIS Server. The users of the Portal come from our SAML provider. In my scripts I want to achieve the map service publishing automation with use of arcpy. To publish an item I obviously need to connect to Portal in first place in my python script. Considering presence of SAML how can I create a connection to Portal with arcpy so that the process could be performed as a scheduled windows batch job? What account would you recommend to use for this process? Should I create a dedicated batch-job account in SAML or actually try to publish via some Porta build-in account, but then would that be possible having SAML? What pattern for this process would you recommend?
Regards,
Szymon
