I'm following this guide to extract pixels with certain rgb code (eg 255,0,0) in a .tif raster using Anaconda 32bit:
RasterToNumPyArray—ArcPy Functions | ArcGIS for Desktop
But I receive this error:
os.chdir("C:\\Users\\ivn\\Desktop\\NumpArr")
filein = os.path.join(os.getcwd(),r'AR00199.tif')
fGDB = "fGDB.gdb"
if not os.path.exists(os.path.join(os.getcwd(),fGDB)):
arcpy.CreateFileGDB_management(os.getcwd(),fGDB)
fileoutgdb = os.path.join(os.getcwd(),r"fGDB.gdb\blocco")
arcpy.env.outputCoordinateSystem = filein
arcpy.env.cellSize = filein
arcpy.env.workspace = os.path.join(os.getcwd(),r"fGDB.gdb")
arcpy.env.scratchWorkspace = os.path.join(os.getcwd(),r"fGDB.gdb")
inRas = arcpy.Raster(filein)
b1 = arcpy.sa.Raster(r'AR00199.tif\Band_1')
b2 = arcpy.sa.Raster(r'AR00199.tif\Band_2')
b3 = arcpy.sa.Raster(r'AR00199.tif\Band_3')
blocksize = 512
blockno = 0
for x in range(0,inRas.width,blocksize):
for y in range(0, inRas.height, blocksize):
blockno += 1
mx = inRas.extent.XMin + x * inRas.meanCellWidth
my = inRas.extent.YMin + y * inRas.meanCellHeight
lx = min([x + blocksize, inRas.width])
ly = min([y + blocksize, inRas.height])
b1nr = arcpy.RasterToNumPyArray(b1,arcpy.Point(mx, my),lx-x, ly-y)
b2nr = arcpy.RasterToNumPyArray(b2,arcpy.Point(mx, my),lx-x, ly-y)
b3nr = arcpy.RasterToNumPyArray(b3,arcpy.Point(mx, my),lx-x, ly-y)
rgb = np.array([b1nr, b2nr,b3nr], np.uint8)
#Operations on blocks....
myRasterBlock = arcpy.NumPyArrayToRaster(output_array,\
arcpy.Point(mx, my),inRas.meanCellWidth,inRas.meanCellHeight)
filetemp = '_'.join([fileoutgdb,str(blockno)])
myRasterBlock.save(filetemp) It save about 173 grids with blocksize = 512 and 73 whit blocksize = 1024 in gdb and then I receive the error... why?? Can someone help?
This is the result of the operation for a block:
