Hi ALL,
i am trying to implement the same with some drill down functionality. when i zoom to village level the point features should be highlighted, displaying their attributes in a table as in this example.
i am getting the values from the layers but not filling in the table. -------- console.log(values3);
where am i going wrong, here is the code
//Populate the dropdown list box with unique values
var FID;
var values3 = [];
var item123 = [];
var testVals3={};
//Add option to display all zoning types to the dropdown list
values3.push({name:""})
var features3 = results3.features;
dojo.forEach (features3, function(feature3) {
FID = feature3.attributes.FID;
if (!testVals3[FID]) {
testVals3[FID] = true;
//values3.push({name:ben_id,shape:feature3.geometry,centroid: feature3.geometry.type === "point" ? feature3.geometry : feature3.geometry.getCentroid()}); // RIYAS: set shape to list store
values3.push(feature3.attributes);
/*values3.push({"ben_id":ben_id,
"ben_name": feature3.attributes.ben_name,
"dname": feature3.attributes.dname,
"father_nam": feature3.attributes.father_nam,
"mname": feature3.attributes.mname,
"scheme_nam": feature3.attributes.scheme_nam,
"uid": feature3.attributes.uid,
"vname": feature3.attributes.vname,
var dataItems3 = {
identifier: 'FID',
label: 'FID',
items: item123
var store3 = new ItemFileReadStore({data:dataItems3});
var grid = registry.byId("grid");
grid.setStore(store3);
grid.on("rowclick", onRowClickHandler);
map.centerAndZoom(center, zoom);
//remove all graphics on the maps graphics layer
//map.graphics.clear();
//Performance enhancer - assign featureSet array to a single variable.
var resultFeatures3 = results3.features;
//Loop through each feature returned
for (var i = 0, il = resultFeatures3.length; i < il; i++) {
//Get the current feature from the featureSet.
//Feature is a graphic
var graphic3 = resultFeatures3;
graphic3.setSymbol(symbol1);
//Set the infoTemplate.
graphic3.setInfoTemplate(infoTemplate3);
//Add graphic to the map graphics layer.
map.graphics.add(graphic3);
// This takes the graphics array you get back from your query and
// gets the overall extent for them. Make sure return geometry is set to
// true in your query.
var extent2 = esri.graphicsExtent(results3.features);
// Use that to set the extent, 1.5 is something I use in my app, but play with
// it to find a setting you like, setting the second parameter to true will get you an extend
// that is at the closest level of your cached service.
map.setExtent(extent2.expand(1.0), true);
function onRowClickHandler(evt) {
var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).FID;
var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
return ((graphic.attributes) && graphic.attributes.FID === clickedTaxLotId);
if ( selectedTaxLot.length ) {
map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
satya
