There are around 50k records in a shapefile feature class. I am using following code block to modify the features.
<SPAN class="keyword token">private</SPAN> <SPAN class="keyword token">async</SPAN> Task <SPAN class="token function">UpdateData</SPAN><SPAN class="punctuation token">(</SPAN>FeatureLayer layer<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN>FeatureClass oInFC <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> featCursor <SPAN class="operator token">=</SPAN> oInFC<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
EditOperation editOperation <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">EditOperation</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
editOperation<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Callback</SPAN><SPAN class="punctuation token">(</SPAN>context <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="keyword token">while</SPAN> <SPAN class="punctuation token">(</SPAN>featCursor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">MoveNext</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> feat <SPAN class="operator token">=</SPAN> featCursor<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//Modify feature attributes</SPAN>
feat<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Store</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
context<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Invalidate</SPAN><SPAN class="punctuation token">(</SPAN>feat<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> oInFC<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">try</SPAN>
<SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> editOperation<SPAN class="punctuation token">.</SPAN><SPAN class="token function">ExecuteAsync</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>result<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">throw</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Exception</SPAN><SPAN class="punctuation token">(</SPAN>editOperation<SPAN class="punctuation token">.</SPAN>ErrorMessage<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN>Exception ex<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">//Handle Exception</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I see a protected memory access violation exception randomly. Any idea why this might be occurring ?
Sai
