Hi,I have some vba code (below) and a .bas file that I'm trying to add to add as an available macro tool. I've loaded the code into the normal.mxt ThisDocument page. I then loaded the .bas file into the modules folder as a new module. But when I go to Tools -> Customize -> Commands tab -> Macros the macro does not appear as a command option. Can anyone guide me here or point me to a helpful site. I had done this before successfully.... but have since gotten a new computer. The macros runs through rasters in a project and exports pngs for each one. Any help is appreciated. What am I doing wrong?!Thanks,DJ
Private Sub ExportRFPMaps_Click()
'MapTasks.ZoomToLayer
'Create variables for map and extent
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pActiveView As IActiveView
Dim pEnv As IEnvelope
Dim strTitle As String
'Set the current map
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
Set pActiveView = pMap
'Loop through the RFP layers turning them on, setting the map title and exporting a .png
'Make sure all RFP layers are off when running the tool or one layer may show up in another's view
For i = 1 To pMap.LayerCount - 1
If pMap.Layer(i) Is Nothing Then Exit Sub 'Test that there is a layer
pActiveView.Extent = pMap.Layer(i).AreaOfInterest 'Set the extent to the layers extent
Set pEnv = pActiveView.Extent 'Set the envelope object equal to the current extent
pEnv.Expand 1.1, 1.1, True 'Expand the envelope by 10%
pActiveView.Extent = pEnv 'Set the extent equal to the expanded envelope
pMap.Layer(i).Visible = True 'Make current layer visible
strTitle = MapTasks.FormatTitle(pMap.Layer(i).Name) 'Format the title into two lines
Call MapTasks.ChangeTitle(strTitle) 'Assign the map title with the change title subc
Call MapTasks.ExportMap("Z:\Informatics\S031\analyses\RossSeaMPA\Modeling\images\eucl_dist\" & pMap.Layer(i).Name & ".png") 'Export map with export map sub
'Turn the layer off unless its the last layer
If i = pMap.LayerCount - 1 Then pMap.Layer(i).Visible = True Else pMap.Layer(i).Visible = False
'Let user know when its done
MsgBox "Export Complete! Files exported to:" & vbCrLf & "Z:\Informatics\S031\analyses\RossSeaMPA\Modeling\images\eucl_dist", vbOKOnly
End Sub
