I am working on a project to characterize watersheds where we are carrying out fieldwork. I am trying to use Summary Statistics to sum all the stream length channels contained in a watershed for multiple feature classes (drainline). Using arcpy.Statistics_analysis creates the output I want in a table but my script overwrites the table instead of adding the sum outputs to the table for each drainline feature. I am unable to figure out how to do this. My script on a subset of the data is below:
<SPAN class="comment token"># Set local variables</SPAN>
ws_drainlines <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Line"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
outStatsTable <SPAN class="operator token">=</SPAN> <SPAN class="string token">"C:/_LOCALdata/AB_ARCHYDRO/AB_ARCHYDRO_NOP.GDB/DrainageDensity"</SPAN>
field <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Watershed"</SPAN>
<SPAN class="comment token"># Sum the drainline lengths for each DrainLine feature</SPAN>
<SPAN class="keyword token">for</SPAN> drainline <SPAN class="keyword token">in</SPAN> ws_drainlines<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>drainline<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN>drainline<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"TEXT"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"20"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management<SPAN class="punctuation token">(</SPAN>drainline<SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'"'</SPAN> <SPAN class="operator token">+</SPAN> drainline <SPAN class="operator token">+</SPAN> <SPAN class="string token">'"'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Statistics_analysis<SPAN class="punctuation token">(</SPAN>drainline<SPAN class="punctuation token">,</SPAN> outStatsTable<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Shape_Length"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SUM"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> field<SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
