Hello, I may be missing an important detail about how Python works, and I wanted to see if anyone could help clarify. Short story short
I needed to obtain a string list of domain values for a certain domain of a featureclass I was using, so I put the following code into python window after looking up the necessary classes/functions I needed to obtain said information.
[x for x in arcpy.da.ListDomains(r'Path_To_Geodatabase') if x.name == u'dPubFunctionalClass'][0].codedValues()
This gave me the following error:
Runtime error
Traceback (most recent call last): File "<string>", line 1, in <module>
TypeError: 'dict' object is not callable
Removing the parenthesis after .codedValues does the trick.
My guess is that .codedValues is not a method of the class Domain, but rather just a variable (a dictionary object) stored within that class. Is this why I get an error message when I attempt to type the .codedValues() instead of just .codedValues?
Thank you!
