Hi all,
I am trying to get bootstraps checkboxes to work with toggling layers. I am not quite sure why it is not working.
Here is the ESRI template script that I modified:
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Explicitly Create Map Service Layer List</title>
<link rel="stylesheet" href="https://community.esri.com//ajax.googleapis.com/ajax/libs/jqueryui/1.11.1/themes/smoothness/jquery-ui.css" />
<link rel="stylesheet" href="https://community.esri.com//maxcdn.bootstrapcdn.com/bootstrap/3.2.0/css/bootstrap.min.css">
<link rel="stylesheet" href="https://community.esri.com//maxcdn.bootstrapcdn.com/bootstrap/3.2.0/css/bootstrap-theme.min.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<script src="http://js.arcgis.com/3.11/"></script>
<script src="//ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1.11.1/jquery-ui.min.js"></script>
<script src="//maxcdn.bootstrapcdn.com/bootstrap/3.2.0/js/bootstrap.min.js"></script>
<script>
var map;
require([
"esri/map",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ImageParameters",
"dojo/dom",
"dojo/on",
"dojo/query",
"dojo/domReady!"
function (Map, ArcGISDynamicMapServiceLayer, ImageParameters, dom, on, query) {
var layer, visibleLayerIds = [];
map = new Map("map");
//Use the ImageParameters to set the visibleLayerIds layers in the map service during ArcGISDynamicMapServiceLayer construction.
var imageParameters = new ImageParameters();
imageParameters.layerIds = [2];
imageParameters.layerOption = ImageParameters.LAYER_OPTION_SHOW;
//can also be: LAYER_OPTION_EXCLUDE, LAYER_OPTION_HIDE, LAYER_OPTION_INCLUDE
layer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer",
{"imageParameters": imageParameters});
map.addLayer(layer);
on(dom.byId("layer0CheckBox"), "change", updateLayerVisibility);
on(dom.byId("layer1CheckBox"), "change", updateLayerVisibility);
function updateLayerVisibility () {
var inputs = query(".list_item");
var inputCount = inputs.length;
//in this application layer 2 is always on.
visibleLayerIds = [2];
for (var i = 0; i < inputCount; i++) {
if (inputs.checked) {
visibleLayerIds.push(inputs.value);
if (visibleLayerIds.length === 0) {
visibleLayerIds.push(-1);
layer.setVisibleLayers(visibleLayerIds);
</script>
</head>
<body>
This sample loads an ArcGISDynamicMapServiceLayer and presents check boxes for only the layers that should be toggled on and off by users. <br />
<br />
Layer List : <span id="layer_list"><div class="btn-group" data-toggle="buttons">
<label class="btn btn-primary active">
<input type="checkbox" class='list_item' id='layer1CheckBox' value=0> cities
</label>
<label class="btn btn-primary">
<input type="checkbox" class='list_item' id='layer0CheckBox' value=1> river
</label>
</div>
</span><br />
<br />
<div id="map" class="claro" style="width:600px; height:400px; border:1px solid #000;"></div>
</body>
</html>
Any help is welcome,
Thank you,
Alex
