for some reason, when selecting a feature onEdit mode, the EditTemplate window is not showing up. I have it setup to custom fields as code below:
appEditor = {
Edit: function (evt) {
// alert(evt);
if (evt === "Permit") {
if (editorWidget) {
editorWidget.destroy();
editorWidget = null;
var txtSewerPermit = new dijit.form.TextBox({
required: false,
promptMessage: "Add Sewer Permit",
style: "height:1.8em; width:260px;margin:2px; background-color:#ffd800"
var txtWaterPermit = new dijit.form.TextBox({
required: false,
promptMessage: "Add Water Permit",
var templateLayers = [permit];
var eDiv = document.createElement("div");
eDiv.id = "editDiv";
document.getElementById('EditContent1').appendChild(eDiv);
var eDivTools = document.createElement("div");
eDivTools.id = "editDivTools";
document.getElementById('EditContent1').appendChild(eDivTools);
map.infoWindow.resize(400, 350);
var editLayerPermit1 = [{
featureLayer: permit,
showDeleteButton: false,
fieldInfos: [
{ 'fieldName': 'Date', 'label': '<table><tr><td style="width:260px;height: 1.8em; margin:2px">Date: </td></tr></table>' },
{ 'fieldName': 'ADDRESS', 'label': '<table><tr><td style="width:260px;height: 1.8em; margin:2px">Address: </td></tr></table>' },
{ 'fieldName': 'SewerPermit', 'label': 'Sewer Permit: ', customField: txtSewerPermit },
{ 'fieldName': 'WaterPermit', 'label': 'Water Permit: ', customField: txtWaterPermit },
'fieldName': 'SERVICE_ID', 'label': 'Add Permit: ', customField: "<br /><b> Sewer Permit</b>: <br />" +
"<div id='progressNumberSP' style='padding:2px; color:red'></div><input type='file' name='fileToUploadSP' id='fileToUploadSP' onclick='if(!getNoneTxt){this.disabled = true; return false}' onchange='uploadFileSP(this.files[0]);' />" +
"<br /><br /><b>Water Permit</b>: <div id='progressNumberWP' style='padding:2px; color:red'></div><input type='file' name='fileToUploadWP' id='fileToUploadWP' onchange='uploadFileWP(this.files[0]);' />"
}]; // editLayers;
var templatePicker = new esri.dijit.editing.TemplatePicker({
featureLayers: templateLayers,
rows: 'auto',
columns: 3
}, 'editDiv');
templatePicker.startup();
var settings = {
map: map,
templatePicker: templatePicker,
layerInfos: editLayerPermit1, //editLayerSitePlan1
toolbarVisible: true,
enableUndoRedo: true
var params = {
settings: settings
editorWidget = new esri.dijit.editing.Editor(params, 'editDivTools');
editorWidget.startup();
}here is the error I get:
TypeError: undefined is not a function {stack: (...), message: "undefined is not a function"} "TypeError: undefined is not a function
at v._createField (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:30:440)
at h._hitchArgs (http://js.arcgis.com/3.10/init.js:173:204)
at Object.h.forEach (http://js.arcgis.com/3.10/init.js:225:144)
at v._createTable (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:28:56)
at v._setCurrentLInfo (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:19:432)
at v._showFeature (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:23:86)
at v._updateSelection (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:20:101)
at v.onLayerSelectionChange (http://js.arcgis.com/3.10/js/esri/dijit/AttributeInspector.js:10:321)
at h.(anonymous function).g [as onSelectionComplete] (http://js.arcgis.com/3.10/init.js:239:390)
rejected at a (http://js.arcgis.com/3.10/init.js:196:337)
at k (http://js.arcgis.com/3.10/init.js:196:89)
at f.then.b.then [as then] (http://js.arcgis.com/3.10/init.js:198:308)
at S.selectFeatures (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:38:212)
at http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:5:469
at Object.h.forEach (http://js.arcgis.com/3.10/init.js:225:179)
at l.selectFeatures (http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:5:325)
at l.selectFeaturesByGeometry (http://js.arcgis.com/3.10/js/esri/dijit/editing/SelectionHelper.js:7:214)
at v._updateSelection (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:39:519)
at null.<anonymous> (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:33:428)
Error
at f.then.b.then [as then] (http://js.arcgis.com/3.10/init.js:198:253)
at h.hitch (http://js.arcgis.com/3.10/init.js:174:23)
at v._updateCurrentFeature (http://js.arcgis.com/3.10/js/esri/dijit/editing/Editor.js:17:126)"
