I have two scripts, first script is to geocode the address and second script is to click anywhere in the map and it creates a circle (1.5 Mile radius) from the clicked point. I want to join these two scripts and the output should be geocode the address and then from the address point draw a circle(which should be static) and get the cell tower points from the feature layer ..
Please let me know the solution as I am fairly new to this language.
SCRIPT ONE:
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Find Address</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body {
height: 100%; width: 100%;
margin: 0; padding: 0;
#map{
padding:0;
border:solid 1px #343642;
margin:5px 5px 5px 0px;
#leftPane{
width:20%;
border-top: solid 1px #343642;
border-left: solid 1px #343642;
border-bottom: solid 1px #343642;
margin:5px 0px 5px 5px;
color: #343642;
font:100% Georgia,"Times New Roman",Times,serif;
/*letter-spacing: 0.05em;*/
</style>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
var map, locator;
require([
"esri/map", "esri/tasks/locator", "esri/graphic",
"esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
"esri/symbols/Font", "esri/symbols/TextSymbol",
"dojo/_base/array", "esri/Color",
"dojo/number", "dojo/parser", "dojo/dom", "dijit/registry",
"dijit/form/Button", "dijit/form/Textarea",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
], function(
Map, Locator, Graphic,
InfoTemplate, SimpleMarkerSymbol,
Font, TextSymbol,
arrayUtils, Color,
number, parser, dom, registry
parser.parse();
map = new Map("map", {
basemap: "streets",
center: [-93.5, 41.431],
zoom: 5
locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
locator.on("address-to-locations-complete", showResults);
// listen for button click then geocode
registry.byId("locate").on("click", locate);
map.infoWindow.resize(200,125);
function locate() {
map.graphics.clear();
var address = {
"SingleLine": dom.byId("address").value
locator.outSpatialReference = map.spatialReference;
var options = {
address: address,
outFields: ["Loc_name"]
locator.addressToLocations(options);
function showResults(evt) {
var symbol = new SimpleMarkerSymbol();
var infoTemplate = new InfoTemplate(
"Location",
"Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}"
symbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE);
symbol.setColor(new Color([153,0,51,0.75]));
var geom;
arrayUtils.every(evt.addresses, function(candidate) {
console.log(candidate.score);
if (candidate.score > 80) {
console.log(candidate.location);
var attributes = {
address: candidate.address,
score: candidate.score,
locatorName: candidate.attributes.Loc_name
geom = candidate.location;
var graphic = new Graphic(geom, symbol, attributes, infoTemplate);
//add a graphic to the map at the geocoded location
map.graphics.add(graphic);
//add a text symbol to the map listing the location of the matched address.
var displayText = candidate.address;
var font = new Font(
"12pt",
Font.STYLE_NORMAL,
Font.VARIANT_NORMAL,
Font.WEIGHT_BOLD,
"Helvetica"
var textSymbol = new TextSymbol(
displayText,
font,
new Color("#666633")
textSymbol.setOffset(0,8);
map.graphics.add(new Graphic(geom, textSymbol));
return false; //break out of loop after one candidate with score greater than 80 is found.
if ( geom !== undefined ) {
map.centerAndZoom(geom, 12);
var map, locator;
/*require([
"esri/map", "esri/layers/FeatureLayer",
"esri/tasks/query", "esri/geometry/Circle",
"esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
"esri/config", "esri/Color", "dojo/dom", "dojo/domReady!", "esri/tasks/locator", "esri.arcgis.utils", "dijit.form.Button",
"dijit.layout.ContentPane", "dijit.layout.BorderContainer", "esri/symbols/Font", "esri/symbols/TextSymbol",
"dojo/_base/array", "dojo/number", "dojo/parser", "dijit/registry", "dijit/form/Button", "dijit/form/Textarea"
function(
Map, FeatureLayer,
Query, Circle,
Graphic, InfoTemplate, SimpleMarkerSymbol,
SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
esriConfig, Color, dom
// use a proxy page if a URL generated by this page is greater than 2000 characters
// this should not be needed as nearly all query & select functions are performed on the client
esriConfig.defaults.io.proxyUrl = "/proxy/";
basemap: "streets",
zoom: 5
//add the census block points in on demand mode. Note that an info template has been defined so when
//selected features are clicked a popup window will appear displaying the content defined in the info template.
var featureLayer = new FeatureLayer
("https://map layer",{
//infoTemplate: new InfoTemplate("CascadeID: ${SOURCE_CAS}", "${*}"),
infoTemplate: new InfoTemplate("Cell Towers"),
outFields: ["SOURCE_CAS","SOURCE_SIT","SOURCE_OEM", "SOURCE_MAR", "SOURCE_LEA", "SOURCE_TOT"]
// selection symbol used to draw the selected census block points within the buffer polygon
SimpleMarkerSymbol.STYLE_CIRCLE,
12,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_NULL,
new Color([247, 34, 101, 0.9]),
new Color([207, 34, 171, 0.5])
featureLayer.setSelectionSymbol(symbol);
//make unselected features invisible
var nullSymbol = new SimpleMarkerSymbol().setSize(0);
featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
map.addLayer(featureLayer);
var circleSymb = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_NULL,
SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
new Color([105, 105, 105]),
), new Color([255, 255, 0, 0.25])
var circle;
//when the map is clicked create a buffer around the click point of the specified distance.
map.on("click", function(evt){
circle = new Circle({
center: evt.mapPoint,
geodesic: true,
radius: 1.5,
radiusUnit: "esriMiles"
//map.infoWindow.hide();
var graphic = new Graphic(circle, circleSymb);
var query = new Query();
query.geometry = circle.getExtent();
//use a fast bounding box query. will only go to the server if bounding box is outside of the visible map
featureLayer.queryFeatures(query, selectInBuffer);
function selectInBuffer(response){
var feature;
var features = response.features;
var inBuffer = [];
//filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
for (var i = 0; i < features.length; i++) {
feature = features;
if(circle.contains(feature.geometry)){
inBuffer.push(feature.attributes[featureLayer.objectIdField]);
query.objectIds = inBuffer;
//use a fast objectIds selection query (should not need to go to the server)
featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
var totalPopulation = sumPopulation(results);
var r = "";
r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>";
dom.byId("messages").innerHTML = r;
function sumPopulation(features) {
var popTotal = 0;
for (var x = 0; x < features.length; x++) {
popTotal = popTotal + features.attributes["POP2000"];
return popTotal;
</script>
</head>
<body class="claro">
<div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'sidebar', gutters:false"
style="width:100%; height:100%;">
<div id="leftPane"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'left'">
Enter an address then click the locate button to use a sample address locator to return the location for
street addresses in the United States.
<br>
<textarea id="address">380 New York St, Redlands</textArea>
<br>
<button id="locate" data-dojo-type="dijit/form/Button">Locate</button>
</div>
<div id="map"
data-dojo-props="region:'center'">
</div>
</div>
</body>
</html>
SCRIPT TWO:
<!DOCTYPE html>
<html>
<head>
on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Select with feature layer</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/tundra/tundra.css">
<style>
html, body, #mapDiv
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#messages
background-color: #fff;
box-shadow: 0 0 5px #888;
font-size: 1.1em;
max-width: 15em;
padding: 0.5em;
position: absolute;
right: 20px;
top: 20px;
z-index: 40;
</style>
<script>
var map, locator;
require([
function(
Map, FeatureLayer,
Query, Circle,
map = new Map("mapDiv", {
basemap: "streets",
center: [-95.249, 38.954],
zoom: 14,
slider: false
//add the cell tower points in on demand mode. Note that an info template has been defined so when
// selection symbol used to draw the selected cell tower block points within the buffer polygon
12,
var circle;
geodesic: true,
radius: 1.5,
var feature;
var inBuffer = [];
feature = features;
var r = "";
var popTotal = 0;
return popTotal;
</script>
</head>
<body>
<span id="messages">Click on the map to select census block points within 1.5 mile.</span>
<div id="mapDiv"></div>
</body>
</html>
