I'm trying to update my app (developed with Flash Builder4.6 SDK 4.6) from AIR 4 api for flex 3.3 to AIR 15 api for flex 3.7.
The app is set to show an initial message and then it loads a basemap.
While there is no problems on Android, IOS 8.1 crashes as soon as it starts loading the basemap.
After many tests i've noticed that the object that causes the issue is the map (com.esri.ags.Map.Map()), that drives up the memory usage up to 80% leading to an immediate crush of the app.
Removing the map object the app starts flawlessly.
Has anyone experienced the same issue? Any idea how to solve it?
Thanks in advance
Michele
