I'd like to question your decision to drop the 'content: '*'' for the popup template ... I won't be hiding my anger and disappointment, because I feel like with each release you just want to p..s us off.
I'd really, really like to know why you dropped the support for simply telling the template do render based on whatever attributes are available for the feature.
And now, I'd really like someone to explain or provide a code that will assign each identified feature from the identify tasks a template using your latest api (4.12), where you have no layer available, but still want to provide all the info available in the attributes, which was easy with '*' before
Thank you
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>esriLib<SPAN class="punctuation token">.</SPAN><SPAN class="token function">all</SPAN><SPAN class="punctuation token">(</SPAN>tasks<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN>resultsArray <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
resultsArray<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>results <SPAN class="operator token">&&</SPAN> results<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> l <SPAN class="operator token">=</SPAN> lyrs<SPAN class="punctuation token">[</SPAN>idx<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Loop through features and embed the feature its layer</SPAN>
results<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">const</SPAN> feature <SPAN class="operator token">=</SPAN> item<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>feature<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="comment token">// Set the symbol. </SPAN>
feature<SPAN class="punctuation token">.</SPAN>symbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapService<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getIdentifyResultSymbol</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Set the layer.</SPAN>
<SPAN class="comment token">// feature.layer = l;</SPAN>
feature<SPAN class="punctuation token">.</SPAN>popupTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>esriLib<SPAN class="punctuation token">.</SPAN>PopupTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
title<SPAN class="punctuation token">:</SPAN> item<SPAN class="punctuation token">.</SPAN>layerName <SPAN class="operator token">||</SPAN> l<SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">,</SPAN>
content<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN><SPAN class="operator token">?</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
features<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>features <SPAN class="operator token">&&</SPAN> features<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Now setup the content for the popup</SPAN>
<SPAN class="keyword token">const</SPAN> popup <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>mapView<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">;</SPAN>
popup<SPAN class="punctuation token">.</SPAN>features <SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">;</SPAN>
popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">open</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
features<SPAN class="punctuation token">:</SPAN> features<SPAN class="punctuation token">,</SPAN>
location<SPAN class="punctuation token">:</SPAN> point
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>popup<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
