import arcpy, os, sys
from arcpy import env
# Set the workspace directory - make sure it's the copied gdb and not the original, in case you mess up
arcpy.env.workspace = r"P:\AFG\GEO\Team\Projects\Shock_Vulnerability\NTL\NTL_201801_202001_AFG_proj_zonalst_copy.gdb"
# Get the list of the zonal stats tables to process
tables = arcpy.ListTables(wild_card="*AFG_proj_zonalst", table_type="ALL")
print (tables)
# iterate through the tables in the gdb and update field names with the file names
for table in tables:
print ("processing: " + table)
# print field names
# iterate through field names in table
for fname in [f.name for f in arcpy.ListFields(tables, wild_card="", field_type="ALL") if not f.required]:
print(fname)
arcpy.AlterField_management(table, f.name, f.name+"_%Name%")
print(fname)
['NTL_QN_202001_AFG_proj_zonalst', 'NTL_201912_AFG_proj_zonalst', 'NTL_201911_AFG_proj_zonalst',
'NTL_201910_AFG_proj_zonalst', 'NTL_201909_AFG_proj_zonalst', 'NTL_201908_AFG_proj_zonalst',
'NTL_201907_AFG_proj_zonalst', 'NTL_201906_AFG_proj_zonalst', 'NTL_201905_AFG_proj_zonalst',
'NTL_201904_AFG_proj_zonalst', 'NTL_201903_AFG_proj_zonalst', 'NTL_201902_AFG_proj_zonalst',
'NTL_201901_AFG_proj_zonalst', 'NTL_201812_AFG_proj_zonalst', 'NTL_201811_AFG_proj_zonalst',
'NTL_201810_AFG_proj_zonalst', 'NTL_201809_AFG_proj_zonalst', 'NTL_201808_AFG_proj_zonalst',
'NTL_201807_AFG_proj_zonalst', 'NTL_201804_AFG_proj_zonalst', 'NTL_201801_AFG_proj_zonalst',
'NTL_201806_AFG_proj_zonalst', 'NTL_201802_AFG_proj_zonalst', 'NTL_201805_AFG_proj_zonalst',
'NTL_201803_AFG_proj_zonalst', 'NTL_202001_AFG_proj_zonalst'] processing: NTL_QN_202001_AFG_proj_zonalst
---------------------------------------------------------------------------OSError
Traceback (most recent call last)<ipython-input-14-596e9c744258> in <module>
16 # print field names
17 # iterate through field names in table
---> 18 for fname in [f.name for f in arcpy.ListFields(tables, wild_card="", field_type="ALL") if not f.required]:
19 print(fname)
20 arcpy.AlterField_management(table, f.name, f.name+"_%Name%")C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py in ListFields(dataset, wild_card, field_type)
1131
1132 * String: Only field types of String are returned."""
-> 1133 return gp.listFields(dataset, wild_card, field_type)
1134
1135 _gptooldoc(None, [[["FeatureLayer", "Table", "TableView", "Dataset", "FeatureDataset"], "", "", ""]])C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py in listFields(self, *args)
346 from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
347 return convertArcObjectToPythonObject(
--> 348 self._gp.ListFields(*gp_fixargs(args, True)))
349 def listIndexes(self, *args):
350 """GP function ListIndexes"""
OSError: "['NTL_QN_202001_AFG_proj_zonalst', 'NTL_201912_AFG_proj_zonalst',
'NTL_201911_AFG_proj_zonalst', 'NTL_201910_AFG_proj_zonalst', 'NTL_201909_AFG_proj_zonalst', 'NTL_201908_AFG_proj_zonalst',
'NTL_201907_AFG_proj_zonalst', 'NTL_201906_AFG_proj_zonalst', 'NTL_201905_AFG_proj_zonalst', 'NTL_201904_AFG_proj_zonalst',
'NTL_201903_AFG_proj_zonalst', 'NTL_201902_AFG_proj_zonalst', 'NTL_201901_AFG_proj_zonalst', 'NTL_201812_AFG_proj_zonalst',
'NTL_201811_AFG_proj_zonalst', 'NTL_201810_AFG_proj_zonalst', 'NTL_201809_AFG_proj_zonalst', 'NTL_201808_AFG_proj_zonalst',
'NTL_201807_AFG_proj_zonalst', 'NTL_201804_AFG_proj_zonalst', 'NTL_201801_AFG_proj_zonalst', 'NTL_201806_AFG_proj_zonalst',
'NTL_201802_AFG_proj_zonalst', 'NTL_201805_AFG_proj_zonalst', 'NTL_201803_AFG_proj_zonalst', 'NTL_202001_AFG_proj_zonalst']" does not exist
