I have added code from the Dynamically Create Layer List sample to my app. It works as expected, except, it loads without my basemap. I have a switch basemap dropdown that still populates with all the ESRI basemaps, however, they don't load when clicked. When I do click on one, it eliminates my DynamicMapServiceLayer. I added the following in the init():layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisprod2/arcgis/rest/services/Dynamic/CountyTest/MapServer"); if (layer.loaded) { buildLayerList(layer); } else { dojo.connect(layer, "onLoad", buildLayerList); }and then separate functions of:function buildLayerList(layer) { var items = dojo.map(layer.layerInfos,function(info,index){ if (info.defaultVisibility) { visible.push(info.id); } return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label>"; }); dojo.byId("layer_list").innerHTML = items.join(' '); layer.setVisibleLayers(visible); map.addLayer(layer); } function updateLayerVisibility() { var inputs = dojo.query(".list_item"), input; visible = []; dojo.forEach(inputs,function(input){ if (input.checked) { visible.push(input.id); } }); //if there aren't any layers visible set the array to be -1 if(visible.length === 0){ visible.push(-1); } layer.setVisibleLayers(visible); }I get the following error in Chrome Developer Tools when I try to switch basemap1. Resource interpreted as Script but transferred with MIME type tex/plain: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServerAny ideas why the basemaps will not load initially or switch?
