Hi,in the samples InfoWindow Custom the InfoWindow is hidden while i panning in the map.How can i set it still visible at the point geometry?I tryed around to disable the code in InfoWindow.js://this._eventConnections.push(dojo.connect(map, "onPanStart", this, this.hide));
and set it to:this._eventConnections.push(dojo.connect(map, "onPanStart", this, this.show));
the InfoWindow is shown, but it lost the anchor to its location pt. In the second try, i set the position back when i start panning.dojo.connect(map, "onPan", function () {
map.infoWindow.show(pt, map.getInfoWindowAnchor(pt));
the code works, but it is not the optimal solution because, the infoWindow is not bind to the background and must jump back every time.Is there a way to make the behavior of the custom InfoWindow like the other InfoWindow samples?Any help on this will be appreciated!!Thanks
