I need some help on my code to count the number of features inside a polygon. I have the following but after testing it, it doesn't seem to be correct. I am trying to figure out how many parcel lots are within the subdivision boundary. My test show after running the code that the "Stats" table has 9 Frequencies but in actually there is 10 parcels within the subdivision. I have tried "HAVE_THEIR_CENTER_IN" but all the results are 1.
import arcpy, os
mxd = arcpy.mapping.MapDocument("current")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
lyr = arcpy.mapping.ListLayers(mxd, "Taxlots")[0]
subs = arcpy.mapping.ListLayers(mxd, "SubsOutsideCities")[0]
#arcpy.MakeFeatureLayer_management(par, "parLyr")
arcpy.SpatialJoin_analysis(subs, lyr,"in_memory/points_SpatialJoin", "JOIN_ONE_TO_MANY", "KEEP_ALL", "", "CONTAINS")
arcpy.Statistics_analysis("points_SpatialJoin", "in_memory/stats", "Join_Count COUNT","OBJECTID")
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
