I just want to load a map service using proxy. I read all of instructions for setting up proxy and proxy set up problems that are asked but I could not solve my problem.
I did following steps:
1- I downloaded the proxy files for .Net. They are proxy.ashx and proxy.config that I put them in a folder named proxy on
my server under inetpub/wwwroot.
2- I edited proxy.config file to contain the paths to my local services.
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
mustMatch="true">
<serverUrls>
<serverUrl url="http://localhost:6080.com"
matchAll="true"/>
</serverUrls>
</ProxyConfig>
First question: I changed url="http://services.arcgisonline.com" to url="http://localhost:6080.com". is it right?
3- I went into IIS Manager and create an application from proxy folder.
My index html code in inetpub/wwwroot:
<!DOCTYPE html>
<html>
<head>
<link rel="stylesheet" href="arcgis_js_api/library/3.14/3.14/esri/css/esri.css">
<title>Create Map and add a dynamic layer</title>
<style>
html, body, #mapDiv{
padding: 0;
margin: 0;
height: 100%;
</style>
<script src="arcgis_js_api/library/3.14/3.14/init.js"></script>
<script>
var map;
require([
"esri/map",
"esri/config",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/geometry/Extent",
"esri/layers/ImageParameters",
], function (
Map,esriConfig, ArcGISDynamicMapServiceLayer,Extent, ImageParameters) {
esriConfig.defaults.io.proxyUrl = "./proxy/proxy.ashx";
esriConfig.defaults.io.alwaysUseProxy = true;
var bounds = new Extent({
"xmin":817962,
"ymin":-187036,
"xmax":1566109,
"ymax":785554,
"spatialReference":{"wkid":32640}
map = new Map("mapDiv", {
extent: bounds
var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://localhost:6080/arcgis/rest/services /sdeMXD/MapServer", {
"opacity" : 0.5
map.addLayer(dynamicMapServiceLayer);
</script>
</head>
<body>
<div id="mapDiv"></div>
</body>
</html>
This is the error in firebug:
SyntaxError: expected expression, got '<' proxy.a...allback (line 1)
| <%@ WebHandler Language="C#" class="proxy" %> |
dojo.io.script error RequestTimeoutError: Timeout exceeded { message="Timeout exceeded", stack=".cache["dojo/errors/crea...4/3.14/init.js:204:284\n", response={...}, more...}
init.js (line 1488)
I spend long time but i could not find out what is wrong with it. I really appreciate it if anybody help me.Thanks in advance
Maria Gomez
