I updated a script to clip wetlands data per county. Some counties work, but for others the Clip analysis fails.
Here is the code:
import arcpy
import time
# Start time
start = time.time()
print('Prepping wetlands county clipped data')
# Enivornment variables
arcpy.env.workspace = 'in_memory'
arcpy.env.outputCoordinateSystem = arcpy.SpatialReference('NAD 1983 UTM Zone 12N')
# Input paths
countyPath = r'Counties'
wetlandsPath = r'UT_Wetlands'
# Output path
outFolder = r'output.gdb'
# Create feature dataset
wetlandsFolder = '{}/Wetlands'.format(outFolder)
if not arcpy.Exists(wetlandsFolder):
arcpy.CreateFeatureDataset_management(outFolder, 'Wetlands')
arcpy.MakeFeatureLayer_management(countyPath, 'countyLayer')
maxCount = len(idList)
count = 1
countyRows = arcpy.SearchCursor(countyPath)
for countyRow in countyRows:
county = str(countyRow.NAME).replace(' ', '_')
outFile = '{}/Wetlands/{}_Wetlands'.format(outFolder, county)
query = '"NAME" = \'' + str(countyRow.NAME) + '\''
arcpy.SelectLayerByAttribute_management('countyLayer', 'NEW_SELECTION', query)
print 'Clipping ' + str(count) + ' out of ' + str(maxCount)
arcpy.Clip_analysis(wetlandsPath, 'countyLayer', outFile)
arcpy.SelectLayerByAttribute_management('countyLayer', 'CLEAR_SELECTION')
count += 1
print 'Working on wetlands for ' + county.replace('_', ' ') + ' county...'
# Here I create variables
# Here I add new fields
# Here I populate the new fields with the created variables
del countyRow, countyRows
# Finish
end = time.time()
print '\nFinished, run time', time.strftime('%M:%S', time.localtime(end - start))The script will work until it gets to SANPETE county, which gives this error:
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
The table was not found.
The table was not found. [SANPETE_Wetlands]
Invalid Topology [Incomplete void poly.]
Failed to execute (Clip).
I've tracked the error to the clip function. At first I thought there was an error in the syntax, then I thought arcpy was getting confused as to where to look for the created clipped feature because I was saving it in memory, then I thought maybe the wetlands data was just too big, or there is something wrong with the attribute data for the SANPETE county, but it's non of those. I tried skipping SANPETE but then it runs for a while and fails in BEAVER county.
I'm running out of ideas as to what it may be. I tried the clip manually in arcMap and it works.
Any suggestions as to what else to try or do you see anything I'm missing in the script?
Michael
