When using this function:
arcpy.da.FeatureClassToNumPyArray(featureClass, "*")
With an asterisk in the second parameter I get this error in Pyscripter:
TypeError: long() argument must be a string or a number, not 'NoneType'
While when I put the name of a field or a some fields I have no problem.
According to ESRI help, this parameter can be populated with:
A list (or tuple) of field names. For a single field, you can use a string instead of a list of strings.
Or use an asterisk (*) instead of a list of fields if you want to access all fields from the input table.
What am I doing wrong?
