Hi.
I'm testing the new Utility Netwok Extension by creating a new water network, as well as using the template from ESRI. I've experienced that ArcGIS Pro is very slow when doing editing and configuring the featureclasses. As an example I've created 5 coded value domains containing 5-10 codes each and when I save the changes, ArcGIS Pro uses about half an hour creating the domains. Creating a new field takes may be 30 seconds to 1 minute. Have anyone else experienced this? When creating a Utility Network from the ESRI template, the process of applying the asset package and loading the data took about 2.5 hours.
I'm running ArcGIS Pro on an Azure machine running windows server 2016, 2.3 x 2.3 GHz processor and 14 Gb memory. The database (SQL Server 2016) is configured on another machine.
