Hello
I am working on automating a process which imports data from local and regional transit authorities, builds a network dataset, and then publishes a Network Analysis service to our ArcGIS Server to use later to solve routing problems.
The process works fine, but the 'build network' step takes quite a long time (8+ hrs) and I was wondering if there are any suggestions of ways I can speed it up.
Network dataset info:
-Global turns only
-No elevation
-End point connectivity
-Roughly 70000 edge features
-Two network attributes added in addition to default Length attribute: one Cost, one Restriction
I am using ArcMap 10.7. Building the network takes a long time both via ArcMap GUI as well as via ArcPy.
Things I have tried:
-changed network attributes from python to vb script
-hardcoded cost and restriction values into the underlying feature class and changed the network dataset attributes to simply read those fields rather than running any script to derive them
