I keep running the Create Vector Tile Package tool in ArcGIS Pro on a custom tiling scheme I created using the Generate Tile Scheme Tool, and I keep encountering the error message:
001854: Tiling scheme must have a 512 x 512 tile size and consecutive scales in a ratio of two.
001854: Tiling scheme must have a 512 x 512 tile size and consecutive scales in a ratio of two.—Help | ArcGIS Desktop
The solution, is obviously to use 512 x 512 and consecutive scales with a ratio of two, which I have set up.
Any clue what I can do to fix this? Here's my custom tiling scheme:
<SPAN class="prolog token"><?xml version="1.0" encoding="utf-8" ?></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>CacheInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:CacheInfo<SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xsi</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema-instance" target="_blank">http://www.w3.org/2001/XMLSchema-instance</A><SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>xs</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.w3.org%2F2001%2FXMLSchema" target="_blank">http://www.w3.org/2001/XMLSchema</A><SPAN class="punctuation token">'</SPAN></SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>typens</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.esri.com%2Fschemas%2FArcGIS%2F10.5" target="_blank">http://www.esri.com/schemas/ArcGIS/10.5</A><SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileCacheInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:TileCacheInfo<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>SpatialReference</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:ProjectedCoordinateSystem<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>PROJCS[<SPAN class="entity token" title=""">"</SPAN>WGS_1984_Web_Mercator_Auxiliary_Sphere<SPAN class="entity token" title=""">"</SPAN>,GEOGCS[<SPAN class="entity token" title=""">"</SPAN>GCS_WGS_1984<SPAN class="entity token" title=""">"</SPAN>,DATUM[<SPAN class="entity token" title=""">"</SPAN>D_WGS_1984<SPAN class="entity token" title=""">"</SPAN>,SPHEROID[<SPAN class="entity token" title=""">"</SPAN>WGS_1984<SPAN class="entity token" title=""">"</SPAN>,6378137.0,298.257223563]],PRIMEM[<SPAN class="entity token" title=""">"</SPAN>Greenwich<SPAN class="entity token" title=""">"</SPAN>,0.0],UNIT[<SPAN class="entity token" title=""">"</SPAN>Degree<SPAN class="entity token" title=""">"</SPAN>,0.0174532925199433]],PROJECTION[<SPAN class="entity token" title=""">"</SPAN>Mercator_Auxiliary_Sphere<SPAN class="entity token" title=""">"</SPAN>],PARAMETER[<SPAN class="entity token" title=""">"</SPAN>False_Easting<SPAN class="entity token" title=""">"</SPAN>,0.0],PARAMETER[<SPAN class="entity token" title=""">"</SPAN>False_Northing<SPAN class="entity token" title=""">"</SPAN>,0.0],PARAMETER[<SPAN class="entity token" title=""">"</SPAN>Central_Meridian<SPAN class="entity token" title=""">"</SPAN>,0.0],PARAMETER[<SPAN class="entity token" title=""">"</SPAN>Standard_Parallel_1<SPAN class="entity token" title=""">"</SPAN>,0.0],PARAMETER[<SPAN class="entity token" title=""">"</SPAN>Auxiliary_Sphere_Type<SPAN class="entity token" title=""">"</SPAN>,0.0],UNIT[<SPAN class="entity token" title=""">"</SPAN>Meter<SPAN class="entity token" title=""">"</SPAN>,1.0],AUTHORITY[<SPAN class="entity token" title=""">"</SPAN>EPSG<SPAN class="entity token" title=""">"</SPAN>,3857]]<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKT</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-20037700<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-30241100<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>YOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>148923141.92838538<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-100000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10000<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MScale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>XYTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ZTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.001<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>MTolerance</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>true<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>HighPrecision</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>102100<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>WKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>3857<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LatestWKID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>SpatialReference</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileOrigin</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:PointN<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>X</SPAN><SPAN class="punctuation token">></SPAN></SPAN>-20037700<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>X</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Y</SPAN><SPAN class="punctuation token">></SPAN></SPAN>30241100<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Y</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileOrigin</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileCols</SPAN><SPAN class="punctuation token">></SPAN></SPAN>512<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileCols</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileRows</SPAN><SPAN class="punctuation token">></SPAN></SPAN>512<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileRows</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>DPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>96<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>DPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LODInfos</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:ArrayOfLODInfo<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LODInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:LODInfo<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>577791.70987213368<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>152.87436231906003<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LODInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>288895.85493606684<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>76.437181159530013<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>144447.92746803342<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>38.218590579765007<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>3<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>72223.96373401671<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>19.109295289882503<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>36111.981867008355<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>9.5546476449412516<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>5<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>18055.990933504178<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4.7773238224706258<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>6<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>9027.9954667520888<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2.3886619112353129<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>7<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4513.9977333760444<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.1943309556176565<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2256.9988666880222<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.59716547780882823<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>9<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1128.4994333440111<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.29858273890441411<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>10<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>564.24971667200555<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.14929136945220706<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>11<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>282.12485833600277<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.074645684726103528<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>12<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>141.06242916800139<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.037322842363051764<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>13<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>70.531214584000693<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.018661421181525882<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>14<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>35.26560729200034<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>907629393<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>15<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>17.63280364600017<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.0046653552953814697<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>16<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>8.8164018230000867<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.0023326776476907353<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>17<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>4.4082009115000433<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.0011663388238453676<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>18<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>2.2041004557500208<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.0005831694119226836<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>19<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LevelID</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1.1020502278750111<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Scale</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0.00029158470596134196<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Resolution</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LODInfos</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>PreciseDPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>96<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>PreciseDPI</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileCacheInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>TileImageInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:TileImageInfo<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>CacheTileFormat</SPAN><SPAN class="punctuation token">></SPAN></SPAN>PNG<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>CacheTileFormat</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>CompressionQuality</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>CompressionQuality</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Antialiasing</SPAN><SPAN class="punctuation token">></SPAN></SPAN>false<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Antialiasing</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>BandCount</SPAN><SPAN class="punctuation token">></SPAN></SPAN>1<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>BandCount</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>LERCError</SPAN><SPAN class="punctuation token">></SPAN></SPAN>0<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>LERCError</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>TileImageInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>CacheStorageInfo</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">xsi:</SPAN>type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">'</SPAN>typens:CacheStorageInfo<SPAN class="punctuation token">'</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>StorageFormat</SPAN><SPAN class="punctuation token">></SPAN></SPAN>esriMapCacheStorageModeCompactV2<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>StorageFormat</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>PacketSize</SPAN><SPAN class="punctuation token">></SPAN></SPAN>128<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>PacketSize</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>CacheStorageInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>CacheInfo</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
