I am trying to set my map extent to the last place it was located when a user comes back to the page. When I use setExtent, the page comes up blank without showing the map at all. I think it may have to do with the spatialReference, but I am not sure. Any help would be appreciated.
require([
"dojo/dom-construct",
"esri/Color",
"esri/dijit/Geocoder",
"esri/dijit/Popup",
"esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/map",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol", "dojo/domReady!",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane"
], function (
domConstruct, Color, Geocoder, Popup, InfoTemplate,
ArcGISDynamicMapServiceLayer, Map, SimpleFillSymbol, SimpleLineSymbol
try {
var sls = new SimpleLineSymbol("solid", new Color("#444444"), 3);
var sfs = new SimpleFillSymbol("solid", sls, new Color([68, 68, 68, 0.25]));
var popup = new Popup({
fillSymbol: sfs,
lineSymbol: null,
markerSymbol: null
}, domConstruct.create("div"));
map = new Map("ui-esri-map", {
basemap: "streets",
center: [-76.347304, 39.533987], // long, lat
zoom: 11,
sliderStyle: "small"
pathArray = location.href.split('/');
protocol = pathArray[0];
host = pathArray[2];
var appFolder = '<%=PavementManagement.Properties.Settings.Default.appFolder %>';
url = protocol + '//' + host;
var _pavementInfoTemplate = new InfoTemplate();
_pavementInfoTemplate.setTitle("<b>Road Condition Information</b>");
_pavementInfoTemplate.setContent("Road Name: ${NAME} <br> Type: ${SURFDESC} <br> From Street: ${FROMSTREET} <br> To Street: ${TOSTREET} <br> Assessed: ${RoadAssessed} <br><a href='" + url + appFolder.replace("none", "") + "/Assessment/AssessmentEntry.aspx?id=${OBJECTID_1}'>Update Road Assessment</a>");
var pavementLayerURL = "http://gismaps.harfordcountymd.gov/arcgis/rest/services/ICT/PavementManagement/MapServer";
var pavementLayerOptions = {
"id": "pavementlineLayer",
"opacity": .5,
"showAttribution": false
var pavementLayer = new ArcGISDynamicMapServiceLayer(pavementLayerURL, pavementLayerOptions);
pavementLayer.setDisableClientCaching(true);
pavementLayer.setInfoTemplates({
0: { infoTemplate: _pavementInfoTemplate }
pavementLayer.setVisibleLayers([0, 1, 2]);
map.addLayer(pavementLayer);
updateExtent(map, pavementLayer);
dojo.connect(map, "onExtentChange", showExtent);
geocoder = new Geocoder({
arcgisGeocoder: {
url: "http://gismaps.harfordcountymd.gov/arcgis/rest/services/ICT/OriginalGeoFencesAddress/GeocodeServer",
placeholder: "Enter Address (No Suffix)",
autonavigate: "True"
map: map
}, "ui-esri-dijit-geocoder");
geocoder.startup();
catch (err) {
alert('error: ' + err);
function updateExtent(map, pavementLayer) {
try{
var Xmin = getCookie('Xmin');
var Ymin = getCookie('Ymin');
var Xmax = getCookie('Xmax');
var Ymax = getCookie('Ymax');
if (typeof Xmin !== 'undefined') {
var startExtent = new esri.geometry.Extent();
startExtent.xmin = parseFloat(Xmin);
startExtent.ymin = parseFloat(Ymin);
startExtent.xmax = parseFloat(Xmax);
startExtent.ymax = parseFloat(Ymax);
startExtent.spatialReference = pavementLayer.spatialReference;
map.setExtent(startExtent);
catch (err) {
