I have seen dev summit doc(http://proceedings.esri.com/library/userconf/devsummit13/papers/devsummit-037.pdf ) says esri has 3d support also.
But could you please provide the details which version of esri javascript lib wil support 3d features like the below api's mentioned in the doc
dojo.require("esri3d.map");
var map = new esri3d.map("map",{viewpoint:initViewPoint});
the above api's are not found in 3.1 lib, please suggest which lib has these features.
we are planning to use esri 3d maps in our organization.
