Hi all-
Does anyone have a workaround for creating a mobile cache in the python 32-bit idle at 10.3 (i.e. at 2.7.8)? After updating to 10.3, the idle can no longer find the _mobile module installed with ArcGIS for Windows Mobile at 10.2, although the desktop tool Create Mobile Cache in 10.3 does run, suggesting that a registry key was deleted/modified? at install. Code below (running at info lic level) returns 'module not found for line 12':
# Import system modules
import sys, string, os, arcpy, time, smtplib
from arcpy import env
# Local variables...
message = ""
current_time = time.asctime()
try:
mapDoc = r"\\servername\arcgisserver\data-store\MobileMaps\ARM360_QueryMap.mxd"
outFolder = r"\\machinename\MobileCacheTests\Arm360\Query Data Cache"
print mapDoc
print outFolder
arcpy.CreateMobileCache_mobile(mapDoc,outFolder,"","NO_ATTACHMENTS","")
except Exception, e:
# If an error occurred, print line number and error message
import traceback, sys
tb = sys.exc_info()[2]
message = message + "Line %i" % tb.tb_lineno
message = message + e.message
# Below is to send email message.
fromAddr = ""
#fromAddr = ""
toAddr = ["",""]
subject = "SCRIPT: Arm360QueryCache"
finish_time = time.asctime()
msgBody = current_time + "\n\n" + message + "\n" + "Thank you." + "\n\n" + finish_time
msg = string.join(("From: %s" %fromAddr, "To: %s" %toAddr, "Subject: %s" %subject, "", msgBody),"")
server = smtplib.SMTP("10.140.65.27")
server.set_debuglevel(1)
server.sendmail(fromAddr,toAddr,msg)
server.quit()Any ideas are appreciated...
David
David Coley
Sarasota County GIS
