I am creating a project to collect attribute field metadata on about 150 feature classes and tables. I have decided to leverage Survey123 (Connect) so that my subject experts can just fill out a survey for each feature class, then I can review and update the metadata on my end. The survey design so far is rather simple and I have shortened my choices list to just (5) feature classes for now.
The solution that I would greatly appreciate some help with is creating a dynamic repeat based on the number of attribute fields in each feature class. Essentially, I have two select_one questions to choose the 'theme' and 'feature class' (theme_list' and 'fcs' in choices list)... what I'd like to see is once the user picks a feature class, the repeat should pull the number of attribute fields ('fields' in the survey choice list) and that's the number of repeats the user is required to fill out.
I have seen some solutions on this subject where folks have had success leveraging a 'fieldcount' integer field to pull the repeat from, which I have tried to no avail...I have left the 'fieldcount' column in the choices list in case there is a helpful friend out there who better understands this solution and wouldn't mind lending some assistance.
Thanks for reading, I appreciate any help!
