I am using ArcGIS 10.2 and SQL Server 2008 R2
I created a database in SQL Server Management Studio, then tried to Enable Enterprise Geodatabase in ArcCatalog but I get the following error message:
The geodatabase system table could not be created.GDB_Tables_Last_Modified : Error (-87)
See the setup log in the following location for additional error information:
C:\Users\mscadmin\AppData\Local\Temp\2\sde_setup.log
Could not create geodatabase schema.
Failed to execute (EnableEnterpriseGeodatabase).
Then the sde_setup.log says:
[Tue Aug 05 13:04:18 2014] Error creating GDB_Tables_Last_Modified table...
[Tue Aug 05 13:04:18 2014] ERROR Creating Geodatabase tables
, Error = -511
,EXT_Error = 0
,EXT_ERROR1 = Invalid layer configuration keyword
,EXT_ERROR2 =
We have been using the same process to create geodatabases on this server for a while, and it was working fine up until a couple months ago. Any help is appreciated.
