I was wondering if anyone has used dojox charting in their web map. I made a test map using the popup and mediainfos type:"linechart", however I need more control over the chart. I need to label the x-axis and invert y-axis in the chart.
So after a lot of searching on google I believe that I need to use dojox charts.
Something like this - http://dojotoolkit.org/reference-guide/1.10/dojox/charting.html
require(["dojox/charting/Chart", "dojox/charting/axis2d/Default", "dojox/charting/plot2d/Lines", "dojo/ready"],
function(Chart, Default, Lines, ready){
ready(function(){
var chart1 = new Chart("simplechart");
chart1.addPlot("default", {type: Lines});
chart1.addAxis("x");
chart1.addAxis("y", {vertical: true});
chart1.addSeries("Series 1", [1, 2, 2, 3, 4, 5, 5, 7]);
chart1.render();
I would like to place a chart like this example in a popup - http://dojotoolkit.org/documentation/tutorials/1.8/charting/demo/monthly-sales.php
I would be very grateful if someone could show an example or give some guidance.
Thank you
Gray
link to test map - HPWD Observation Mapâ
This is my current code
<!DOCTYPE html>
<html>
<head>
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title>Simple Map</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
<style>
html, body, #map {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
</style>
<script src="http://js.arcgis.com/3.10/"></script>
<script>
var map;
require(["esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer", "esri/dijit/Popup", "esri/dijit/PopupTemplate", "dojo/domReady!"],
function(Map, Tiled, FeatureLayer, Popup, PopupTemplate) {
map = new Map("map", {
basemap: "topo",
center: [-102.040536, 34.188206], // longitude, latitude
zoom: 13
var tiled = new Tiled("http://gis.hpwd.com/arcgisweb/rest/services/obswells2014v2/MapServer");
map.addLayer(tiled);
var template = new PopupTemplate({
title: "HPWD Water Levels",
description: "Observation Well Number: {StateWellN}",
fieldInfos: [{ //define field infos so we can specify an alias
fieldName: "DTW_2004",
label: "2004"
fieldName: "DTW_2005",
label: "2005"
fieldName: "DTW_2006",
label: "2006"
fieldName: "DTW_2007",
label: "2007"
fieldName: "DTW_2008",
label: "2009"
fieldName: "DTW_2009",
label: "2009"
fieldName: "DTW_2010",
label: "2010"
fieldName: "DTW_2011",
label: "2011"
fieldName: "DTW_2012",
label: "2012"
fieldName: "DTW_2013",
label: "2013"
fieldName: "DTW_2014",
label: "2014"
mediaInfos:[{ //define the bar chart
caption: "",
type:"linechart",
value:{
fields:["DTW_2004","DTW_2005","DTW_2006","DTW_2007","DTW_2008","DTW_2009","DTW_2010","DTW_2011","DTW_2012","DTW_2013","DTW_2014"]
var featureLayer = new FeatureLayer("http://gis.hpwd.com/arcgisweb/rest/services/obswells2014v2/MapServer/1",{
mode: FeatureLayer.MODE_ONDEMAND,
outFields: ["*"],
infoTemplate: template
map.addLayer(featureLayer);
</script>
</head>
<body>
<div id="map"></div>
</body>
</html>
