I'm still fairly new to ArcGIS Pro, so forgive me for anything obvious I'm overlooking.
I'm attempting to add a network dataset to a map and then export it as a mobile map package. I've followed the instructions here (Create Mobile Map Package—Data Management toolbox | ArcGIS Desktop ) and my network dataset follows all of the conventions described on this page. When I build it I receive no errors. However, when I open it in my WPF application, the TransportationNetworks object is always null.
Is there a way to verify through ArcGIS Pro that the network dataset actually made it into the package? If that is the case then I can determine whether or not the problem is in my WPF application. If the network dataset isn't being included, then what am I failing to do?
I'm not sure what other information might be needed, so please tell me what else I should provide.
